Help Anyone on complete stock Evo V? Need APN Settings
Enazsem
If you could, I dunno if you can on stock, but go to the Voice Dialer app and say "Open APNs" and screenshot all of those settings, scroll up and down and make sure you get everything. I have a theory, more of a semi educated guess, why MMS won't work on some ROMs. I checked and some settings are not set at all in that section. If we have the stock settings we could manually input them and hopefully that's a fix.
I am totally stock, no root, no s-off. I went to voice dialer and all I got was a blank screen with an "APNs" heading.
I have the sprint variation but a co-worker has the evo v. Will try to take a peak in a bit. I did root it for her though, but only htc dev unlock, custom recovery, super user. She's still on the stock rom, I don't think any APN settings should have been changed or anything...
Tell me what you found.
The APN settings should show up on the stock messenger. Just go to Settings > Multimedia messages (MMS) > Connection settings.
I would take a screenshot of mine, but my fields are blank since I don't have service on this phone...
I'm not on stock.
Here ya go.
Sorry, I just checked in the mms settings as suggested above. I can look somewhere else if you want. I'm not very familiar with apn settings because I've never had to mess with them.
Man if you can that'd be great. I've been scouring the web trying to collect information. What I found so far that works is this. My MMS seems severely delayed though. So it's more of a work in progress.
Tell me exactly where you want me to to look. I will check Monday when I'm at work :) happy to help, I'm just in unfamiliar territory here ;)
Go to Voice Dialer app and say Open APNs after which just open it up and they should be there.
I am on stock, no root, no s-off, nothing. Doing that function pulls upa blank screen. When I hit the menu button I have the option of New APN and Reset to default.
