Anyone tried RoundR?
Oh yeah. Yours is a bit less subtle than mine lol. My radius is 24 :)
Its a bit annoying that its built into my rom and actually a part of the rom's settings menu because on Play it says theres an update but it wont let me update and i cant leave a review because, obviously, its side loaded :)
A couple of things I don't like about Roundr:
It stays in your notifications as ongoing.
And apparently it messes up your clock and the settings icon when in notifications.
Sorry about the poor graphics. It's hot today and my S3 phone screen is hard to draw on/with.
If you're on 4.3..
Persistent notifications are usually the result of the app developer not following Google's guidelines.
That's why they made the switch in 4.3 to make it persistent if they did it the "wrong" way, to try to force them to do it "right" ;)
I dont get the persistant notification but as i said its baked into the rom. Have you long-pressed the notification and unchecked the show notifications box to see if it still sticks?
Cool. And does RoundR still stick after a reboot mate?
What im gona ask the dev for is separate radius settings, one for home screen and another for everywhere else :)
Yeah, it's there after a reboot.
You might ask him to remove it from the notifications screen. If it can be done.
