Accessories Anyone use an FM Transmitter?
especially from cellphoneshop.com..... i would not buy it. personally i have never had an fm transmitter work the way i wanted it too, even had one hard wired to power and inline with my car antennae direct to my stock head unit and it was crappy.
you are much better off going hardwired. for your home stereo its easy. you would need an rca to 3.5mm stereo calbe. boom. done. for your car start here i know it says they are ipod interfaces, but they also have standard aux rca inputs that would use the same type of cable your home stereo should use. definitley more expensive but guaranteed to be a crystal clear signal.
