Help Anyone using Pandora with Motorokr T505...HELP
Megasean
When I first started using the T505, the volume up (to change the song) and play/pause button worked with Pandora. The 3rd time I tried to use the T505 with pandora the buttons stopped working. Then I tried using the T505 with Last.FM and the buttons worked perfectly. I was wondering if anyone else had this problem and if they found a solution....I already tried to uninstall and reinstall pandora but that did nothing.
I use the T505 and haven't had a problem with it while listening to Pandora. I used to have constant drop outs prior to 2.01, but since it has worked fine. Sounds like the problem may be with the T505, I've noticed when the battery gets low it can act a little strange.
It works the way it should with everything but pandora. So i'm thinking its pandora. I guess Ill just have to lunge forward while driving to skip a song :(
