Help AnyonSingle MMS being sent as slideshow???
eye4863
Anyone know how to stop or go around the fact that a single picture message gets sent as a slide show? It's not that big of a deal just one of those little nuances I'd like to tweak... Ok well main reason being on some phones you'd have to save the slide show after it plays just to be able to view it and zoom etc... Thanks
yup, I just realized this the other day when I sent a pic to my wife. I didnt bother to check on it though. Maybe there is a way to change the setting. I will check later..
Yeah this really irritated me as well. Could not find a way to fix it in the settings. My "work around" was downloading "Handcent" messaging from the app market. Problem solved. It has way more option ayhow.
if i can actually send an MMS it works. really irritated the phone will send them after a battery pull but not after a little.
I think it is... I actually like i better now that I have all the settings the way i want. It'll take a little while to get all the settings the way you want them but then again that's what so good about it... customized messaging. give it a shot... I think you'll like it. Make sure to turn off your original text app or you'll get duplicates though.
I found the reason for MMS slideshow and was able to recreate it multiple times.
Using iPhone 4 I created message with photo in this order:
1. Typed text
2. Inserted picture (regardless from photo gallery or take it while crating a message)
3. Press Send.
The message comes as slide show.
If I create message with photo in this order:
1. Inserted picture (regardless from photo gallery or take it while crating a message)
2. Typed text
3. Pressed Send.
The message comes as image with text below.
I don't know if this is intentional or not. I asked my wife to remember to attach image first, then type text. If she forgets, I will remind her.
Hope that helps.
I downloaded and installed Handcent and I'm still having the same issue. anything sent from email or downloaded from a source are still saved as slide show. Is there a setting I'm missing in the Handcent options? Pics taken and sent from a phone are fine.
any help will be highly appreciated. thanks
Please wait for a Samsung Agent to respond.
You are now chatting with 'Amanda'. There will be a brief survey at the end of our chat to share feedback on my performance today.
Your Issue ID for this chat is LTK5640539248X
Amanda: Hi, thank you for contacting Samsung Technical Support. How may I help you today?
Visitor: Question, I have a Samsung Infuse, when i receive a MMS picture it shows as a slide show
Visitor: Is there a way to fix this
Amanda: Please allow me to go through the inquiry.
Visitor: Thank you for your help
Amanda: I understand that you want to change the MMS settings in the phone. Am I correct?
Visitor: Yes
Amanda: Thank you for confirming.
Amanda: Let me check for the information on your request from our database.
Amanda: I have checked the information on your request, MMS settings are default on the phone from the carrier they can't be edited and modified. However are you getting the slide show option for only for single picture or all the pictures in your phone?
Visitor: Single or mulitple pictures
Amanda: Are you facing the issue with all the pictures in your phone?
Visitor: Yes
Visitor: Is there a way to disable the slideshow feature on the phone
Amanda: Let me check it for you.
Visitor: Thank you
Amanda: I will be right with you.
Visitor: ok
Amanda: Thank you for waiting. I'll be with you in just a moment.
Amanda: Well, I have checked the complete information on your request.
Amanda: It is the default feature on your phone it can not be disabled from the phone.
Amanda: I apologize for the inconvenience caused to you.
Visitor: Can any of this be changed by the carrier
Amanda: I would have surely provided you the information if any settings were available on the phone.
Visitor: Ok thank you for your assitance with this and you have a wonderful night
