Anyway to keep the sence toolbar?
djb28
Using Launcher Pro, I would like to use the Sense bar that has the shut off for WIFI, Bluetooth, Brightness. Is there a way, Or an app that also does this? Sorry if I am calling it something else. I dont know what it is called.
You can use the Android Power Control widget. It has toggles for Wifi, Bluetooth, GPS, Sync, and Brightness. It's already on your phone and accessible from LP.
I was able to find that. Thanks. Now I have a stuck google widget. I can not select it and drag it down. I can make it smaller, But it is at the top of my screen and will not let me select it to do anything to it other than resize it. Strange.
EDIT. No sooner did i post this. I set my phone down. It went to landscape. I was then able to grab that widget and pull it down. LOL. unreal.
To move it, press and hold until the phone vibrates, then move it to the desired location. If you press and hold then let go, you can resize. Don't let go until you move it.
