Aokp-rom?
I'm having trouble getting 3g/sms/mms working on AOKP. I'm otherwise loving the rom, but those are kinda critical features. I flashed the mms/vvm fix but it didn't seem to help. What modem are you using?
I'm using fj12. Everything is working for me. Never had a problem.. Make sure to do a clean install
Ya, I'm going to reflash to stock fj12 ics and then start over from there. Hopefully that clears everything up, I'm tired of touchwiz.
I flashed AOKP (Magical Unicorn) with the MMS fix and so far it's working really nice... it doesn't seem to have any of the issues that CM10.1 had.... so far so good
Hmm I don't use visual voicemail so I didn't flash the patch that fixes it... there were 2 parts to the fix (MMS fix and VVM fix). I'm guessing that if the MMS fix worked, the VVM should work too
I got VVM and MMS to work fine on AOKP. I've switched to PACman since then and haven't looked back. It's the best rom I've tried, but like any other AOSP based rom I have intermittent GPS failures and other minor radio issues.
  • Like
Reactions: cpk
