I'm rooted n unlocked... Previous Rom was 2fast fuzion. I've been going back n forth with this Rom trying 2 get the market n root 2 work. No luck so far
i may be able to help here, if you have clockworkmod recovery just use the fix permissions feature under advanced to fix root, might also want to update super user and install busybox.
as for market try force stopping google frameworks service and deleting the cache files for it, restart then try your market again.
I'm having a problem with the play store. Every time I try to install an app it says "Unknown error code during install: "-110"" Can anyone help? I love this rom and I would love to keep using it. Thanks!Please report any issues and if you have them, a possible fix. I would recommend not deleting any of the other HTC files as I have tried most of them and something ends up breaking.
Aside from the core phone and contacts apk's none are of significant size nor using up any resources. The Sense UI now uses about 4.5 mb of RAM in a background process which if stopped causes errors but not a total crash and at 4.5 Mb not worth the headaches of trying to stop it.
Build.prop may need some editing for the USB connection....mass_storage OR mtp.....and adb
Also every time when I try to install a .apk file, it won't let me install. I have changed to developer options to allow non-market sources.I'm having a problem with the play store. Every time I try to install an app it says "Unknown error code during install: "-110"" Can anyone help? I love this rom and I would love to keep using it. Thanks!
