Okay, so I just installed AOSP 0.9.9.2. My CM6 was acting up (not receiving texts unless I flashed to Liquid Sense then did a nand restore) so I switched to this. There's a couple of little quirky things which I need some help on.
1. At the lock screen, "Menu - Menu" doesn't seem to unlock my phone. I miss being able to do that. Is there a setting I'm missing?
2. The "Power Control" widget no longer has the 3G or Airplane mode option. Again, in CM6 I remember there being a place to configure which options are shown. I can't seem to find where to do that.
3. In CM6 I got used to having the battery percentage on top of the icon. Is there any way to get that on AOSP?
4. Without using ADW Launcher or something, can I remove 2 home screens? I only need 3, and would like to remove the far left and far right screens.
That's all I can think of atm, but I'm sure there'll be more.
Thanks for your help.
