Root AOSP Theme for EVO Flashable Zip Works On 2.2 Signed
Mr Puffin
his is my first release of a theme or anything so i hope you like it screenshots are included
original post at AOSP Theme for EVO Flashable Zip Works On 2.2 Signed - xda-developers
What it Does
Themes the following
check boxes (some of the HTC ones remain un-themed)
volume indicator (yellow)
taskbar (white)
all taskbar icons -BT, wifi, 3g, battery, 4g
menu selections (yellow AOSP selection)
power menu icons
what it doesn't do
it does not change the application icons except for settings
if you want aosp themed app icons i would suggest NonSence or bugless
Things to work out
the location service icon has been removed but still takes up a space in the taskbar (i do not know how to remove that so any help would be nice)
____________________________________________________________
DOWNLOADS
For 2.2 Roms (08/23/2010)
Vanilla Lock AKA Flipz
Clear Lock -Will Release Soon
Stock Lock - Will Release Soon
Bar Lock - Will Release Soon
Black Task Bar with Aosp icons as requested by ericwgarza1
Flash one of the above files first if you would like to have full theme then flash the black Taskbar zip
For Android 2.1 Below this Point
*thank you konikub for letting me use your theme to fix this for ruu it wouldn't be up otherwise be sure to check out his work*
Clear Lock
Stock Lock
Bar Lock
old versions
Flipz Lock Screen
Stock Lock Screen
Clear Lock Screen
Credits
google for making the original theme
flipzmode for the lockscreen (Info about Flipz Lock Here)
Konikub for helping with the ruu
and of course all the devs who make roms for us
and me for putting together the zip for evo
