ironass
Extreme Android User
For those of you that use the excellent Apex Launcher, there is a beta update available that improves speed and performance as well as Android 4.1, (Jelly Bean), transitions.
Changelog
"Rebuilt based on Android 4.1.1 Launcher:
Fixed icon ordering bug within folders
When placing widgets on the screen, everything else automatically moves to make room
When they are too big, widgets resize on their own to fit on the homescreen
Quickly remove apps/widgets by flinging them to the edge of the homescreen
Added background for widgets in the drawer
New app enter/exit animations (JB only)
Switched to phone layout on 7″ tablets (e.g., Nexus 7)
Major performance boost for homescreen and drawer
Other Improvements and fixes include:
Unlimited drawer tabs and new drawer management UI (pro)
Improved drawer tab switching for vertical drawers (pro)
Fixed Play Store widgets on JellyBean
Updated translations
Fixed paid theme (icon pack) issue on JellyBean
Lots of other improvements and enhancements"
If you are currently running Apex Launcher Pro, you can download the beta version .apk, (install as per any .apk file), by going to:-
Apex settings > About Apex Launcher > Automatically check for updates > Beta version.
Alternatively, you can download and install the .apk from their xda forum, here.
Changelog
