Root APK Installation
smccue
I am trying to figure out how to install APK files that are on my SD card to add items missing in ROMs. Any help would be appreciated.
you need a file manager like es file manager or root explorer to install it. just use the app and navigate to your card and find the file and select install.
Use Astro file manager to find the files and click (touch) the file to load it. Or another file manager to do it. I think that should work for ya.
