Root apk tool issue ( solved )
phillvela7
Hows it going gentle men and madams . Im having a error when i try to compile systemui.apk . Ill post a pic , im wondering if anyone else has had this issue . If so , would you guys mind helping me out ? I though it might be something to do with writing a bad line , but i tried decompiling the apk then without any modification compiling it back . Same error came out . Thanks in advance , i might just try compiling with another tool but just wondering if theres a way to fix my issue seeing that i already have this one installed .
Sorry , not systemui.apk . Its freamework-res.apk
Never mind , i found a work around . I just copied the decompiled apk in my computer to my sd and used ninja morph to compile . Thanks guys .
So i tried it , i noticed ninja morph compiled it and the size is 7.56 mb . I looked at the original framework-res.apk but the size is 7.78 mb . Maybe it might mess something up since theres something missing . Not sure though , im going to try it anyway . I doubt it will cause problems since i tried changing pictures with ninjamorph on framework-res.apk before . I extracted it with ninja morph , edited the files with ninja morph compiled it back up with ninja morph and the file was much smaller then the original . By far much less then 7.56mb installed with root explorer , rebooted . Everything seemed ok . Just be warned that it may cause issues since its not the exact same size .
By the way , i did not modify anything on this one , it was just a test run to see if it would work . Like i stated before original was 7.78 , used apk tool to extract the framework-res.apk , moved to sd . Compiled with ninja morph and now its 7.56 with no modifications .
Im about to be a test dummy for what i said , about to paste in system and reboot . If i brick , see you guys soon . Ill post up pics if it works .
