Root APN settings for metro needed
getitnowmarketing
I'm hard at work on a aosp build for Opt M and need some help for the apns. I've never had metro and they don't even have service in my area so I need you guys to provide me the data.
I need to make a apn-conf.xml and of course its not utilized in the oem setup. After reverse engineering the mms.apk I found the hidden mms settings in a file aptly called hidden_settings.xml. Contents are
Code:
<PreferenceScreen>
&#8722;
<PreferenceCategory android:title="MMS SETTING" android:key="pref_mmsc_settings">
<ListPreference android:entries="@array/mmsc_list" android:title="SERVER" android:key="mmsc_select" android:defaultValue="SP_PRODUCT" android:dialogTitle="Select MMSC Server" android:entryValues="@array/mmsc_list"/>
<EditTextPreference android:title="@string/strSrvMMSURL" android:key="srv_mms_url_set" android:summary="@string/strSrvMMSURL" android:defaultValue="http://mms.metropcs.net:3128/mmsc"/>
<EditTextPreference android:title="@string/strSrvMMSPort" android:key="srv_mms_port_set" android:summary="@string/strSrvMMSPort" android:defaultValue="3128"/>
<EditTextPreference android:title="@string/strSrvMMSAgent" android:key="srv_mms_agent_set" android:summary="@string/strSrvMMSAgent" android:defaultValue="LG-MS690"/>
<EditTextPreference android:title="@string/strSrvMMSProfile" android:key="srv_mms_profile_set" android:summary="@string/strSrvMMSProfile" android:defaultValue="http://uaprof.metropcs.net/UAProf/LG-MS690.xml"/>
<EditTextPreference android:title="Gateway" android:key="srv_mms_proxy_set" android:defaultValue=""/>
</PreferenceCategory>
</PreferenceScreen>
I was thinking the internet stuff may be in the wapservice.apk but could not find the settings inside it. I'm hoping metro isn't using some bs wap proxy for the internet. Can some users comfirm and hopefully supply the correct settings for me.
With an active provisioned phone can someone with root explorer go to /data/data/com.providers.telephony/telephony.db and give me the settings out of it in the carrier.db. Make sure to scroll to the right to get them all.
I need to make a template such as this one for vzw.
Code:
<apns version="6">
<apn carrier="Verizon" mcc="310" mnc="004" apn="" user="*" server="*" password="*" mmsc="http://mms.vtext.com/servlets/mms"/>
<apn name="Production" numeric="310012" mcc="310" mnc="012" apn="1" user="null" server="null" password="null" proxy="null" port="" mmsproxy="" mmsport="" mmsprotocol="2.0" mmsc="http://mms.vtext.com/servlets/mms" type="mms"/>
</apns>
All lookups on the internet seem to require metro to use a tcp redirect through a proxy for internet on flashed android phones and I'm hoping its not the case on this device being native.
Im also assuming these from build.prop are correct for mmc/mnc
ro.cdma.home.operator.alpha=MetroPCS
ro.cdma.home.operator.numeric=311660
2.2 MPCS-
apns-conf.xml
Code:
<?xml version="1.0" encoding="utf-8"?>
** Copyright 2006, The Android Open Source Project
** Licensed under the Apache License, Version 2.0 (the "License");
** you may not use this file except in compliance with the License.
** You may obtain a copy of the License at
**     http://www.apache.org/licenses/LICENSE-2.0
** Unless required by applicable law or agreed to in writing, software
** distributed under the License is distributed on an "AS IS" BASIS,
** WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
** See the License for the specific language governing permissions and
** limitations under the License.
<!-- use empty string to specify no proxy or port -->
<!-- If you edit this version, also edit the version in the partner-supplied
    apns-conf.xml configuration file -->
<apns version="6">
<!-- GW620 Eve setting Starts -->
  <!-- GB O2 default and MMS -->
	<apn carrier="O2 Pay monthly"
		mcc="234"
		mnc="10"
		apn="wap.o2.co.uk"
		user="o2wap"
		server=""
		password="password"
		proxy="193.113.200.195"
		port="8080"
		mmsproxy="193.113.200.195"
		mmsport="8080"
		mmsc="http://mmsc.mms.o2.co.uk:8002"
		type=""
		preferapp="" />
  <!-- GB O2_PrePaid default and MMS -->
	<apn carrier="O2 Pay and Go"
		mcc="234"
		mnc="10"
		apn="payandgo.o2.co.uk"
		user="payandgo"
		server=""
		password="password"
		port="8080"
		mmsport="8080"
		type=""
		preferapp="" />
  <!-- GB ASDA default and MMS -->
	<apn carrier="ASDA WAP"
		mcc="234"
		mnc="15"
		apn="asdamobiles.co.uk"
		user="wap"
		server=""
		password="wap"
		proxy="212.183.137.012"
		port="8799"
		mmsproxy="212.183.137.012"
		mmsport="8799"
		mmsc="http://mms.asdamobiles.co.uk/servlets/mms"
		type=""
		preferapp="" />
  <!-- GB H3G default and MMS -->
	<apn carrier="3 Services"
		mcc="234"
		mnc="20"
		apn="three.co.uk"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy="mms.three.co.uk"
		mmsport="8799"
		mmsc="http://mms.um.three.co.uk:10021/mmsc"
		type=""
		preferapp="" />
  <!-- GB ORG default-->
	<apn carrier="Orange Internet"
		mcc="234"
		mnc="33"
		apn="orangeinternet"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
  <!-- GB ORG MMS-->
	<apn carrier="Orange MMS"
		mcc="234"
		mnc="33"
		apn="orangemms"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy="192.168.224.010"
		mmsport="8080"
		mmsc="http://mms.orange.co.uk/"
		type="mms"
		preferapp="" />
  <!-- GB TalkMobile default-->
	<apn carrier="Talkmob WAP"
		mcc="234"
		mnc="15"
		apn="talkmobile.co.uk"
		user="wap"
		server=""
		password=""
		port="8799"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
  <!-- GB TalkMobile MMS-->
	<apn carrier="Talkmob PAYG MMS"
		mcc="234"
		mnc="15"
		apn="payg.talkmobile.co.uk"
		user="wap"
		server=""
		password="wap"
		proxy=""
		port=""
		mmsport="8799"
		mmsc="http://mms.talkmobile.co.uk/servlets/mms"
		type="mms"
		preferapp="" />
  <!-- GB Tesco default and MMS -->
	<apn carrier="Tesco WAP GPRS"
		mcc="234"
		mnc="10"
		apn="prepay.tesco-mobile.com"
		user="tescowap"
		server=""
		password="password"
		port="8080"
		mmsport="8080"
		type=""
		preferapp="" />
  <!-- GB T-Mobile default and MMS -->
	<apn carrier="T-Mobile Internet"
		mcc="234"
		mnc="30"
		apn="general.t-mobile.uk"
		user="t-mobile"
		server=""
		password="tm"
		proxy=""
		port=""
		mmsproxy="149.254.201.135"
		mmsport="8080"
		mmsc="http://mmsc.t-mobile.co.uk:8002"
		type=""
		preferapp="" />
		mcc="234"
		mnc="31"
		user="t-mobile"
		server=""
		password="tm"
		proxy=""
		port=""
		mmsport="8080"
		type=""
		preferapp="" />
		mcc="234"
		mnc="32"
		user="t-mobile"
		server=""
		password="tm"
		proxy=""
		port=""
		mmsport="8080"
		type=""
		preferapp="" />
  <!-- GB Virgin default and MMS -->
	<apn carrier="Virgin GPRS"
		mcc="234"
		mnc="30"
		apn="goto.virginmobile.uk"
		user="user"
		server=""
		password=""
		proxy="193.030.166.004"
		port="8080"
		mmsproxy="193.030.166.002"
		mmsport="8080"
		mmsc="http://mms.virginmobile.co.uk:8002"
		type=""
		preferapp="" />
  <!-- GB VDF default and MMS -->
	<apn carrier="Contract WAP"
		mcc="234"
		mnc="15"
		apn="wap.vodafone.co.uk"
		user="wap"
		server=""
		password="wap"
		port="8799"
		mmsport="8799"
		mmsc="http://mms.vodafone.co.uk/servlets/mms"
		type=""
		preferapp="" />
  <!-- PL ERA default-->
	<apn carrier="Era WAP"
		mcc="260"
		mnc="02"
		apn="erainternet"
		user=""
		server=""
		password=""
		proxy="213.158.194.229"
		port="8080"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
  <!-- PL ERA MMS-->
	<apn carrier="Era MMS"
		mcc="260"
		mnc="02"
		apn="eramms"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy="213.158.194.226"
		mmsport="8080"
		mmsc="http://mms.era.pl/servlets/mms"
		type="mms"
		preferapp="" />
  <!-- PL Heyah default-->
	<apn carrier="Heyah WAP"
		mcc="260"
		mnc="02"
		apn="heyah.pl"
		user="heyah"
		server=""
		password="heyah"
		port="8080"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
  <!-- PL Heyah MMS-->
	<apn carrier="Heyah MMS"
		mcc="260"
		mnc="02"
		apn="heyahmms"
		user="heyah"
		server=""
		password="heyah"
		proxy=""
		port=""
		mmsport="8080"
		mmsc="http://mms.heyah.pl/servlets/mms"
		type="mms"
		preferapp="" />
  <!-- PL ORG default-->
	<apn carrier="Orange WAP"
		mcc="260"
		mnc="03"
		apn="wap"
		user="wap"
		server=""
		password="wap"
		proxy="192.168.006.102"
		port="8080"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
		mcc="260"
		mnc="03"
		apn="internet"
		user="internet"
		server=""
		password="internet"
		proxy=""
		port=""
		mmsproxy=""
		mmsport=""
		mmsc=""
		type=""
		preferapp="" />
  <!-- PL ORG MMS-->
		mcc="260"
		mnc="03"
		apn="mms"
		user="mms"
		server=""
		password="mms"
		proxy=""
		port=""
		mmsproxy="192.168.006.104"
		mmsport="8080"
		mmsc="http://mms.orange.pl"
		type="mms"
		preferapp="" />
  <!-- PL Play default-->
	<apn carrier="Play WAP"
		mcc="260"
		mnc="06"
		apn="wap"
		user=""
		server=""
		password=""
		proxy="010.010.025.005"
		port="8080"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
	<!--PL Play Internet-->
	<apn carrier="Play Internet"
		mcc="260"
		mnc="06"
		apn="internet"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy=""
		mmsport=""
		mmsc=""
		type=""
		preferapp="" />
  <!-- PL Play MMS-->
	<apn carrier="Play MMS"
		mcc="260"
		mnc="06"
		apn="mms"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy="010.010.025.005"
		mmsport="8080"
		mmsc="http://10.10.28.164/mms/wapenc"
		type="mms"
		preferapp="" />
  <!-- PL Plus default-->
	<apn carrier="Plus WAP"
		mcc="260"
		mnc="01"
		apn="wap.plusgsm.pl"
		user=""
		server=""
		password=""
		proxy="212.002.096.016"
		port="8080"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
  <!-- PL Plus MMS-->
	<apn carrier="Plus MMS"
		mcc="260"
		mnc="01"
		apn="mms.plusgsm.pl"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy="212.002.096.016"
		mmsport="8080"
		mmsc="http://mms.plusgsm.pl:8002/"
		type="mms"
		preferapp="" />
  <!-- PT Optimus default and MMS -->
	<apn carrier="Optimus"
		mcc="268"
		mnc="03"
		apn="umts"
		user=""
		server=""
		password=""
		proxy="062.169.066.005"
		port="8799"
		mmsproxy="062.169.066.005"
		mmsport="8799"
		mmsc="http://mmsc:10021/mmsc"
		type=""
		preferapp="" />
    <!-- PT TMN default-->
	<apn carrier="wap tmn"
		mcc="268"
		mnc="06"
		apn="wap.tmn.pt"
		user="tmn"
		server=""
		password="tmnnet"
		proxy="172.030.002.022"
		port="80"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
  <!-- PT TMN MMS-->
	<apn carrier="MMS TMN"
		mcc="268"
		mnc="06"
		apn="mmsc.tmn.pt"
		user="tmn"
		server=""
		password="tmnnet"
		proxy=""
		port=""
		mmsproxy="010.111.002.016"
		mmsport="8080"
		mmsc="http://mmsc/"
		type="mms"
		preferapp="" />
  <!-- PT VDF default-->
	<apn carrier="Vodafone life!"
		mcc="268"
		mnc="01"
		apn="wap.vodafone.pt"
		user="wap"
		server=""
		password="wap"
		proxy="172.016.019.050"
		port="8799"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
	<apn carrier="Internet Vodafone"
	    mcc="268"
		mnc="01"
		apn="internet.vodafone.pt"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy=""
		mmsport=""
		mmsc=""
		type=""
		preferapp=""
  <!-- PT VDF MMS-->
	<apn carrier="MMS Vodafone"
		mcc="268"
		mnc="01"
		apn="vas.vodafone.pt"
		user="vas"
		server=""
		password="vas"
		proxy=""
		port=""
		mmsproxy="213.030.027.063"
		mmsport="8799"
		mmsc="http://mms/servlets/mms"
		type="mms"
		preferapp="" />
  <!-- SW 3SE default and MMS -->
	<apn carrier="Planet 3"
		mcc="240"
		mnc="02"
		apn="data.tre.se"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy="mmsproxy.tre.se"
		mmsport="8799"
		mmsc="http://mms.tre.se"
		type=""
		preferapp="" />
		mcc="240"
		mnc="04"
		apn="data.tre.se"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsport="8799"
		type=""
		preferapp="" />
  <!-- SW Tele2 default and MMS -->
	<apn carrier="Tele2 WAP"
		mcc="240"
		mnc="05"
		apn="internet.tele2.se"
		user=""
		server=""
		password=""
		proxy="130.244.196.090"
		port="8080"
		mmsproxy="130.244.202.30"
		mmsport="8080"
		mmsc="http://mmsc.tele2.se"
		type=""
		preferapp="" />
		mcc="240"
		mnc="07"
		user=""
		server=""
		password=""
		port="8080"
		mmsport="8080"
		type=""
		preferapp="" />
  <!-- SW Telenor default-->
	<apn carrier="TelenorMobilsurf"
		mcc="240"
		mnc="08"
		apn="services.telenor.se"
		user=""
		server=""
		password=""
		proxy="172.030.253.241"
		port="8799"
		mmsproxy="172.30.253.241"
		mmsport="8799"
		mmsc="http;//mms"
		type=""
		preferapp="" />
  <!-- SW Telia default-->
	<apn carrier="Telia SurfPort"
		mcc="240"
		mnc="01"
		apn="online.telia.se"
		user=""
		server=""
		password=""
		proxy="010.254.254.254"
		port="8080"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
  <!-- SW Telia MMS-->
	<apn carrier="Telia MMS"
		mcc="240"
		mnc="01"
		apn="mms.telia.se"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy="193.209.134.132"
		mmsport="80"
		mmsc="http://mmss"
		type="mms"
		preferapp="" />
		mcc="240"
		mnc="05"
		user=""
		server=""
		password=""
		port="8080"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
		mcc="240"
		mnc="05"
		apn="mms.telia.se"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsport="80"
		mmsc="http://mmss"
		type="mms"
		preferapp="" />
  <!-- IE 3 default and MMS -->
		mcc="272"
		mnc="05"
		apn="3ireland.ie"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy="mms.3ireland.ie"
		mmsport="8799"
		mmsc="http://mms.um.3ireland.ie:10021/mmsc"
		type=""
		preferapp="" />
  <!-- IE Meteor default-->
	<apn carrier="Meteor WAP"
		mcc="272"
		mnc="03"
		apn="wap.mymeteor.ie"
		user="my"
		server=""
		password="wap"
		proxy="010.085.085.085"
		port="8799"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
  <!-- IE Meteor MMS-->
	<apn carrier="Meteor MMS"
		mcc="272"
		mnc="03"
		apn="mms.mymeteor.ie"
		user="my"
		server=""
		password="wap"
		proxy=""
		port=""
		mmsproxy="010.085.085.085"
		mmsport="8799"
		mmsc="http://mms.mymeteor.ie"
		type="mms"
		preferapp="" />
  <!-- IE O2 default and MMS -->
	<apn carrier="O2.ie Mobile Internet"
		mcc="272"
		mnc="02"
		apn="internet"
		user=""
		server=""
		password=""
		proxy="062.040.032.040"
		port="8080"
		mmsproxy="062.040.032.040"
		mmsport="8080"
		mmsc="http://mmsc.mms.o2.ie:8002/"
		type=""
		preferapp="" />
  <!-- IE VDF default-->
	<apn carrier="Vodafone Live!"
		mcc="272"
		mnc="01"
		apn="live.vodafone.com"
		user=""
		server=""
		password=""
		proxy="010.024.059.100"
		port="80"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
  <!-- IE VDF MMS-->
	<apn carrier="Vodafone MMS"
		mcc="272"
		mnc="01"
		apn="mms.vodafone.net"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy="010.024.059.200"
		mmsport="80"
		mmsc="http://www.vodafone.ie/mms"
		type="mms"
		preferapp="" />
  <!-- CZ O2 default-->
	<apn carrier="O2 internet"
		mcc="230"
		mnc="02"
		apn="internet"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
  <!-- CZ O2 MMS-->
	<apn carrier="O2 MMS"
		mcc="230"
		mnc="02"
		apn="mms"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy="160.218.160.218"
		mmsport="8080"
		mmsc="http://mms.o2active.cz:8002"
		type="mms"
		preferapp="" />
  	<apn carrier="t-zones"
		mcc="230"
		mnc="01"
		apn="wap.t-mobile.cz"
		user="wap"
		server=""
		password="wap"
		proxy="010.000.000.010"
		port="80"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
		mcc="230"
		mnc="01"
		apn="internet.t-mobile.cz"
		user="wap"
		server=""
		password="wap"
		proxy=""
		port=""
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
	<apn carrier="T-Mobile MMS"
		mcc="230"
		mnc="01"
		apn="mms.t-mobile.cz"
		user="mms"
		server=""
		password="mms"
		proxy=""
		port=""
		mmsproxy="010.000.000.010"
		mmsport="80"
		mmsc="http://mms"
		type="mms"
		preferapp="" />
  	<apn carrier="Vodafone live!"
		mcc="230"
		mnc="03"
		apn="data.vodafone.cz"
		user="wap"
		server=""
		password="wap"
		proxy="010.011.010.011"
		port="80"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
	<apn carrier="Internet"
		mcc="230"
		mnc="03"
		apn="internet"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
	<apn carrier="MMS"
		mcc="230"
		mnc="03"
		apn="mms"
		user="mms"
		server=""
		password="mms"
		proxy=""
		port=""
		mmsproxy="010.011.010.111"
		mmsport="80"
		mmsc="http://mms"
		type="mms"
		preferapp="" />
  <!-- FR Virgin default-->
	<apn carrier="Virgin mobile WAP"
		mcc="208"
		mnc="01"
		apn="ofnew.fr"
		user="orange"
		server=""
		password="orange"
		proxy="192.168.010.100"
		port="8080"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
  <!-- FR Virgin MMS-->
	<apn carrier="Virgin mobile MMS"
		mcc="208"
		mnc="01"
		apn="orange.acte"
		user="orange"
		server=""
		password="orange"
		proxy=""
		port=""
		mmsproxy="192.168.010.200"
		mmsport="8080"
		mmsc="http://mms.orange.fr"
		type="mms"
		preferapp="" />
  <!-- GR Cosmote default-->
	<apn carrier="Cosmote WAP"
		mcc="202"
		mnc="01"
		apn="wap"
		user=""
		server=""
		password=""
		proxy="010.010.010.010"
		port="8080"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
  	<apn carrier="Cosmote E-mail"
		mcc="202"
		mnc="01"
		apn="internet"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy=""
		mmsport=""
		mmsc=""
		type=""
		preferapp="" />
  <!-- GR Cosmote MMS-->
	<apn carrier="Cosmote MMS"
		mcc="202"
		mnc="01"
		apn="mms"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy="010.010.010.020"
		mmsport="9201"
		mmsc="http://mmsc.cosmote.gr:8002"
		type="mms"
		preferapp="" />
  <!-- KR LGE default-->
	<apn carrier="LGE DEFAULT"
		mcc="450"
		mnc="00"
		apn="tbt"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp=""/>
  <!-- KR LGE MMS-->
	<apn carrier="LGE MMS"
		mcc="450"
		mnc="00"
		apn="qe"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy="203.229.247.28"
		mmsport="8000"
		mmsc="http://203.229.247.29/lgeqe"
		type="mms"
		preferapp=""/>
  <!-- FI elisa default-->
	<apn carrier="elisa WAP"
		mcc="244"
		mnc="05"
		apn="wap"
		user=""
		server=""
		password=""
		proxy="213.161.040.040"
		port="80"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp=""/>
	<apn carrier="elisa Internet"
		mcc="244"
		mnc="05"
		apn="internet"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp=""/>
  <!-- FI elisa MMS-->
	<apn carrier="elisa MMS"
		mcc="244"
		mnc="05"
		apn="mms"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy="213.161.041.057"
		mmsport="80"
		mmsc="http://mms.elisa.fi"
		type="mms"
		preferapp=""/>
 <!-- FI dna default-->
  	<apn carrier="dna WAP"
		mcc="244"
		mnc="12"
		apn="wap"
		user=""
		server=""
		password=""
		proxy="010.001.001.001"
		port="8080"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp=""/>
	<apn carrier="dna Internet"
		mcc="244"
		mnc="12"
		apn="internet"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp=""/>
	<apn carrier="dna MMS"
		mcc="244"
		mnc="12"
		apn="mms"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy="010.001.001.002"
		mmsport="8080"
		mmsc="http://mmsc.dnafinland.fi"
		type="mms"
		preferapp=""/>
  <!-- FI Saunalahti default-->
  	<apn carrier="Saunalahti WAP"
		mcc="244"
		mnc="21"
		apn="wap.saunalahti.fi"
		user=""
		server=""
		password=""
		proxy="062.142.004.197"
		port="8080"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp=""/>
	<apn carrier="Saunalahti Internet"
		mcc="244"
		mnc="21"
		apn="internet.saunalahti"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp=""/>
	<apn carrier="Saunalahti MMS"
		mcc="244"
		mnc="21"
		apn="mms.saunalahti.fi"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy="062.142.004.197"
		mmsport="8080"
		mmsc="http://mms.saunalahti.fi:8002/"
		type="mms"
		preferapp=""/>
	<apn carrier="Saunalahti Email"
		mcc="244"
		mnc="21"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp=""/>
  <!-- FI SONERA default and MMS -->
  	<apn carrier="Sonera WAP"
		mcc="244"
		mnc="91"
		apn="wap.sonera.net"
		user=""
		server=""
		password=""
		proxy="195.156.025.004"
		port="8080"
		mmsproxy="195.156.025.033"
		mmsport="8080"
		mmsc="http://mms.sonera.fi:8002"
		type=""
		preferapp=""/>
	<apn carrier="Sonera Internet"
		mcc="244"
		mnc="91"
		apn="internet"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp=""/>
  <!-- BELGIUM Base default-->
	<apn carrier="BASE WAP"
		mcc="206"
		mnc="20"
		apn="gprs.base.be"
		user="base"
		server=""
		password="base"
		proxy="172.031.198.037"
		port="5080"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp=""/>
  <!-- BELGIUM Base MMS-->
	<apn carrier="Base MMS"
		mcc="206"
		mnc="20"
		apn="mms.base.be"
		user="base"
		server=""
		password="base"
		proxy=""
		port=""
		mmsproxy="217.072.235.0018"
		mmsport="8080"
		mmsc="http://mmsc.base.be"
		type="mms"
		preferapp=""/>
	  <!-- BELGIUM Mobistar DEFAULT-->
	<apn carrier="Orange World"
		mcc="206"
		mnc="10"
		apn="mworld.be"
		user=""
		server=""
		password=""
		proxy="212.065.063.143"
		port="8080"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp=""/>
	<apn carrier="VOX GPRS"
		mcc="206"
		mnc="10"
		apn="vox.lu"
		user=""
		server=""
		password=""
		proxy="212.088.139.044"
		port="8080"
		mmsproxy="212.088.139.044"
		mmsport="8080"
		mmsc="http://mms.vox.lu"
		type=""
		preferapp=""/>
  <!-- BELGIUM Mobistar MMS -->
	<apn carrier="Mobistar MMS"
		mcc="206"
		mnc="10"
		apn="mms.be"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy="212.065.063.143"
		mmsport="8080"
		mmsc="http://mmsc.mobistar.be"
		type="mms"
		preferapp=""/>
	<!-- BELGIUM Proximus Default-->
	<apn carrier="Px Live"
		mcc="206"
		mnc="01"
		apn="wap.proximus.be"
		user="wap"
		server=""
		password="wap"
		proxy="010.253.007.003"
		port="8080"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp=""/>
  <!-- BELGIUM Proximus MMS-->
	<apn carrier="Px MMS"
		mcc="206"
		mnc="01"
		apn="EVENT.PROXIMUS.BE"
		user="mms"
		server=""
		password="mms"
		proxy=""
		port=""
		mmsproxy="010.055.014.075"
		mmsport="8080"
		mmsc="http://mmsc.proximus.be/mms"
		type="mms"
		preferapp=""/>
	<!-- DENMARK 3DK Default-->
	<apn carrier="3"
		mcc="238"
		mnc="06"
		apn="data.tre.dk"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy="mmsproxy.3.dk"
		mmsport="8799"
		mmsc="http://mms.3.dk"
		type=""
		preferapp=""/>
	<!-- DENMARK Call me Default-->
	<apn carrier="Call me GPRS"
		mcc="238"
		mnc="20"
		apn="webSP"
		user=""
		server=""
		password=""
		proxy="062.044.158.029"
		port="8080"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp=""/>
  <!-- DENMARK Call me MMS-->
	<apn carrier="Call me MMS"
		mcc="238"
		mnc="20"
		apn="mmsSP"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy="193.209.134.131"
		mmsport="8080"
		mmsc="http://mms.telia.dk"
		type="mms"
		preferapp=""/>
	<!-- DENMARK CBB Mobil Default-->
	<apn carrier="CBB WAP GPRS"
		mcc="238"
		mnc="02"
		apn="internet"
		user=""
		server=""
		password=""
		proxy="212.088.064.008"
		port="8080"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp=""/>
  <!-- DENMARK CBB Mobil MMS-->
	<apn carrier="CBB MMS"
		mcc="238"
		mnc="02"
		apn="sonofon"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy="212.088.064.008"
		mmsport="8080"
		mmsc="http://mms.sonofon.dk"
		type="mms"
		preferapp=""/>
	<!-- DENMARK DLG Tele Default-->
	<apn carrier="DLG Tele GPRS"
		mcc="238"
		mnc="20"
		apn="webSP"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp=""/>
  <!-- DENMARK DLG Tele MMS-->
	<apn carrier="DLG Tele MMS"
		mcc="238"
		mnc="20"
		apn="mmsSP"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsport="8080"
		type="mms"
		preferapp=""/>
	<apn carrier="Telia SurfPort GPRS"
		mcc="238"
		mnc="30"
		apn="www.internet.mtelia.dk"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp=""/>
		mcc="238"
		mnc="30"
		apn="www.mms.mtelia.dk"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsport="8080"
		type="mms"
		preferapp=""/>
	<!-- DENMARK TDC Default-->
	<apn carrier="TDC WAP"
		mcc="238"
		mnc="01"
		apn="wap"
		user=""
		server=""
		password=""
		proxy="194.182.251.015"
		port="8080"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp=""/>
  <!-- DENMARK TDC MMS-->
	<apn carrier="TDC MMS"
		mcc="238"
		mnc="01"
		apn="mms"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy="194.182.251.015"
		mmsport="8080"
		mmsc="http://192.168.241.114:8002"
		type="mms"
		preferapp=""/>
	<!-- DENMARK Telenor Default-->
	<apn carrier="Telenor WAP"
		mcc="238"
		mnc="02"
		apn="internet"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp=""/>
  <!-- DENMARK Telenor MMS-->
	<apn carrier="Telenor MMS"
		mcc="238"
		mnc="02"
		apn="telenor"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsport="8080"
		mmsc="http://mms.telenor.dk"
		type="mms"
		preferapp=""/>
	<!-- DENMARK Telia Default-->
		mcc="238"
		mnc="20"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp=""/>
  <!-- DENMARK Telia MMS-->
		mcc="238"
		mnc="20"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsport="8080"
		type="mms"
		preferapp=""/>
	<!-- DENMARK Telmore Default-->
	<apn carrier="Telmore WAP"
		mcc="238"
		mnc="01"
		apn="wap"
		user=""
		server=""
		password=""
		port="8080"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp=""/>
  <!-- DENMARK Telmore MMS-->
	<apn carrier="Telmore MMS"
		mcc="238"
		mnc="01"
		apn="mms"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsport="8080"
		type="mms"
		preferapp=""/>
	<!--Norway Chess WAP-->
	<apn carrier="Chess Mobil"
		mcc="242"
		mnc="02"
		apn="netcom"
		user=""
		server=""
		password=""
		proxy="010.254.254.010"
		port="8080"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
	<!--NORWAY CHESS MMS-->
	<apn carrier="Chess MMS"
		mcc="242"
		mnc="02"
		apn="mms.netcom.no"
		user="mms"
		server=""
		password="netcom"
		proxy=""
		port=""
		mmsproxy="212.169.066.004"
		mmsport="8080"
		mmsc="http://mm/"
		type="mms"
		preferapp=""/>
	<!--Norway Netcom WAP-->
	<apn carrier="NetCom Mobil"
		mcc="242"
		mnc="02"
		apn="netcom"
		user=""
		server=""
		password=""
		port="8080"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
	<!--NORWAY Netcom MMS-->
	<apn carrier="NetCom MMS"
		mcc="242"
		mnc="02"
		apn="mms.netcom.no"
		user="mms"
		server=""
		password="netcom"
		proxy=""
		port=""
		mmsport="8080"
		mmsc="http://mm/"
		type="mms"
		preferapp=""/>
	<!--Norway Tele2 WAP-->
		mcc="242"
		mnc="02"
		apn="internet.tele2.no"
		user=""
		server=""
		password=""
		port="8080"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
	<!--NORWAY Tele2 MMS-->
	<apn carrier="Tele2 MMS"
		mcc="242"
		mnc="02"
		apn="mms.tele2.no"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy="193.012.040.014"
		mmsport="8080"
		mmsc="http://mmsc.tele2.no"
		type="mms"
		preferapp=""/>
	<!--Norway Telenor WAP-->
	<apn carrier="Entry"
		mcc="242"
		mnc="01"
		apn="telenor"
		user=""
		server=""
		password=""
		port="8080"
		mmsproxy="010.010.010.011"
		mmsport="8080"
		mmsc="http://mmsc/"
		type=""
		preferapp="" />
 <!-- NL AH_Mobiel default-->
	<apn carrier="AH Mobiel Internet"
		mcc="204"
		mnc="12"
		apn="multimedia.ah.nl"
		user=""
		server=""
		password=""
		port="8080"
		mmsport="8080"
		mmsc="http://mms"
		type=""
		preferapp="" />
  <!-- NL KPN default-->
	<apn carrier="Mobiel Internet"
		mcc="204"
		mnc="08"
		apn="portalmmm.nl"
		user=""
		server=""
		password=""
		proxy="010.010.100.020"
		port="5080"
		mmsproxy="010.010.100.020"
		mmsport="5080"
		mmsc="http://mp.mobiel.kpn/mmsc"
		type=""
		preferapp="" />
		mcc="204"
		mnc="12"
		apn="portalmmm.nl"
		user=""
		server=""
		password=""
		port="5080"
		mmsport="5080"
		type=""
		preferapp="" />
  <!-- NL Rabo Mobiel default-->
	<apn carrier="Rabo Mobiel Int"
		mcc="204"
		mnc="08"
		apn="rabo"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy="010.010.100.010"
		mmsport="5080"
		type=""
		preferapp="" />
	<!--Netherland T-Mobile WAP-->
	<apn carrier="web'n'walk"
		mcc="204"
		mnc="16"
		apn="internet"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
	<!--Netherland T-Mobile MMS-->
		mcc="204"
		mnc="16"
		apn="telenor"
		user="tmobilemms"
		server=""
		password="tmobilemms"
		proxy=""
		port=""
		mmsport="8080"
		mmsc="http://t-mobilemms"
		type="mms"
		preferapp=""/>
		mcc="204"
		mnc="20"
		apn="internet"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
		mcc="204"
		mnc="20"
		apn="telenor"
		user="tmobilemms"
		server=""
		proxy=""
		port=""
		mmsport="8080"
		type="mms"
		preferapp=""/>
	<!--Netherland Tele2 WAP-->
	<apn carrier="Tele2 GPRS"
		mcc="204"
		mnc="02"
		apn="internet.tele2.nl"
		user=""
		server=""
		password=""
		proxy="8080"
		port="130.244.196.090"
		mmsproxy="193.012.040.064"
		mmsport="8080"
		mmsc="http://mmsc.tele2.nl"
		type=""
		preferapp="" />
	<!--Netherland Telfort WAP-->
	<apn carrier="Telfort Spot"
		mcc="204"
		mnc="12"
		apn="internet"
		user=""
		server=""
		password=""
		proxy="8080"
		port="193.113.200.195"
		mmsport="8080"
		mmsc="http://mms"
		type=""
		preferapp="" />
		mcc="204"
		mnc="08"
		apn="internet"
		user=""
		server=""
		password=""
		proxy="8080"
		mmsport="8080"
		mmsc="http://mms"
		type=""
		preferapp="" />
	<!--Netherland Vodafone WAP-->
		mcc="204"
		mnc="04"
		apn="live.vodafone.comt"
		user="vodafone"
		server=""
		password="vodafone"
		proxy="8799"
		port="192.168.251.150"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
	<!--Netherland Vodafone MMS-->
		mcc="204"
		mnc="04"
		user="vodafone"
		server=""
		password="vodafone"
		proxy=""
		port=""
		mmsproxy="192.168.251.150"
		mmsport="8799"
		mmsc="http://mmsc.mms.vodafone.nl"
		type="mms"
		preferapp=""/>
	<!--Greece Vodafone WAP1-->
	<apn carrier="Vf live!"
		mcc="202"
		mnc="05"
		apn="wap.vodafone.gr"
		user="user"
		server=""
		password="pass"
		proxy="5080"
		port="213.249.019.049"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
	<!--Greece Vodafone WAP2-->
	<apn carrier="Vf live! Prepay"
		mcc="202"
		mnc="05"
		apn="wapkarta.vodafone.gr"
		user="user"
		server=""
		password="pass"
		proxy="5080"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
	<!--Greece Vodafone WAP3-->
	<apn carrier="Vodafone Internet"
		mcc="202"
		mnc="05"
		apn="internet.vodafone.gr"
		user="user"
		server=""
		password="pass"
		proxy=""
		port=""
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
	<!--Greece Vodafone MMS-->
	<apn carrier="Vf MMS"
		mcc="202"
		mnc="05"
		user="user"
		server=""
		password="pass"
		proxy=""
		port=""
		mmsproxy="213.249.019.049"
		mmsport="5080"
		mmsc="http://mms.vodafone.gr"
		type="mms"
		preferapp=""/>
		<!--Greece Wind WAP-->
	<apn carrier="WIND Plus"
		mcc="202"
		mnc="10"
		apn="gwap.b-online.gr"
		user=""
		server=""
		password=""
		proxy="192.168.200.010"
		port="9401"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
	<apn carrier="WIND E-mail"
		mcc="202"
		mnc="10"
		apn="gint.b-online.gr"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy=""
		mmsport=""
		mmsc=""
		type=""
		preferapp="" />
	<!--Greece Wind MMS-->
	<apn carrier="WIND MMS"
		mcc="202"
		mnc="10"
		apn="mnet.b-online.gr"
		user=""
		server=""
		password=""
		proxy=""
		port=""
		mmsproxy="192.168.200.011"
		mmsport="9401"
		mmsc="http://192.168.200.95/servlets/mms"
		type="mms"
		preferapp=""/>
	<!--Netherland Tele2 WAP & MMS-->
		mcc="204"
		mnc="07"
		user=""
		server=""
		password=""
		port="8080"
		mmsport="8080"
		type=""
		preferapp="" />
	<apn carrier="SKT"
		mcc="450"
		mnc="05"
		apn="nate.sktelecom.com"
		user=""
		server="*"
		password=""
		proxy=""
		port="80"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
	<apn carrier="KTF"
		mcc="450"
		mnc="08"
		apn="default.ktfwing.com"
		user=""
		server="*"
		password=""
		proxy=""
		port="80"
		mmsproxy=""
		mmsport=""
		mmsc=""
		type="default"
		preferapp="" />
	<!-- hopemini@lge.com, Emulator -->
    <apn carrier="TelKila"
        mcc="310"
        mnc="260"
        apn="internet"
        user="*"
        server="*"
        password="*"
        mmsc="null"
	<apn carrier="Orange France"
		mcc="208"
		mnc="01"
		apn="orange"
		user="orange"
		server=""
		password="orange"
		proxy=""
		port="80"
		mmsproxy=""
		mmsport=""
		mmsc="" />
	<apn carrier="VF DE Web"
		mcc="262"
		mnc="02"
		apn="web.vodafone.de"
		user="guest"
		server=""
		password="guest"
		proxy=""
		port="80"
		mmsproxy=""
		mmsport=""
		mmsc="" />
	<apn carrier="VF Spain"
		mcc="214"
		mnc="01"
		apn="airtelnet.es"
		user="vodafone"
		server=""
		password="vodafone"
		proxy=""
		port="9201"
		mmsproxy=""
		mmsport=""
		mmsc="" />
	<apn carrier="Telefonica(Movistar)"
		mcc="214"
		mnc="07"
		apn="movistar.es"
		user="movistar"
		server=""
		password="movistar"
		proxy=""
		port="9201"
		mmsproxy=""
		mmsport=""
		mmsc="" />
	<!-- by hopemini@lge.com, 2008-06-18, no id, no passwd
		<apn carrier="OPENWAVE"
		mcc="450"
		mnc="00"
		apn="tb"
		user="lge"
		server=""
		password="lge"
		proxy=""
		port="80"
		mmsproxy=""
		mmsport=""
		mmsc=""
	<apn carrier="LGE"
		mcc="450"
		mnc="00"
		apn="tbt"
		user=""
		server=""
		password=""
		proxy=""
		port="80"
		mmsproxy=""
		mmsport=""
		mmsc="" />
    <apn carrier="Cingular 410"
         mcc="310"
         mnc="410"
         apn="wap.cingular"
         user="WAP@CINGULARGPRS.COM"
         server="cingulargprs.com"
         password="CINGULAR1"
         mmsc="http://mmsc.cingular.com/"
    <apn carrier="Cingular 170 Pacific Bell"
         mcc="310"
         mnc="170"
         apn="wap.cingular"
    <apn carrier="Cingular 380 ATT"
         mcc="310"
         mnc="380"
         apn="proxy"
         user="*"
         server="*"
         password="*"
    <!-- TODO: add mms, proxy settings. -->
    <apn carrier="Rogers"
         mcc="302"
         mnc="720"
         apn="internet.com"
         user="guest"
         password="guest"
    <apn carrier="Chunghwa"
         mcc="466"
         mnc="92"
         apn="internet"
         user="*"
         server="*"
         password="*"
         mmsc="null"
    <apn carrier="TWN GSM"
         mcc="466"
         mnc="97"
         apn="internet"
         user="*"
         server="*"
         password="*"
         mmsc="null"
    <apn carrier="Far EasTone"
         mcc="466"
         mnc="01"
         apn="internet"
         user="*"
         server="*"
         password="*"
         mmsc="null"
    <apn carrier="KGT-Online"
         mcc="466"
         mnc="88"
         apn="internet"
         user="*"
         server="*"
         password="*"
         mmsc="null"
    <apn carrier="India Hutch"
         mcc="404"
         mnc="86"
         apn="portalnmms"
         user="*"
         server="*"
         password="*"
         proxy="10.10.1.100"
         port="9401"
         mmsc="http://mms1.hutchworld.co.in/mms/"
    <apn carrier="SFR"
         mcc="208"
         mnc="10"
         apn="websfr"
         user="*"
         server="*"
         password="*"
         proxy="195.115.25.129"
         port="8080"
         mmsc="null"
    <apn carrier="Vodafone UK"
         mcc="234"
         mnc="15"
         apn="internet"
         user="web"
         server="user"
         password="*"
         mmsc="null"
    <apn carrier="IL Orange"
         mcc="425"
         mnc="01"
         apn="internet"
         user="*"
         server="*"
         password="*"
         mmsc="null"
    <apn carrier="IL Cellcom"
         mcc="425"
         mnc="02"
         apn="internetg"
         user="*"
         server="*"
         password="*"
         mmsc="null"
    <apn carrier="IL Pelephone"
         mcc="425"
         mnc="03"
         apn="internet"
         user="*"
         server="*"
         password="*"
         mmsc="null"
    <apn carrier="Jawwal Palestine"
         mcc="425"
         mnc="05"
         apn="internet"
         user="*"
         server="*"
         password="*"
         mmsc="null"
   <apn carrier="Swisscom GPRS"
        mcc="228"
        mnc="01"
        apn="gprs.swisscom.ch"
        user="*"
        server="*"
        password="*"
        mmsc="null"
   <apn carrier="ERA"
        mcc="260"
        mnc="02"
        apn="erainternet"
        user="erainternet"
        server=""
        password="erainternet"
        mmsc="null"
    <apn carrier="CMCC"
       mcc="460"
       mnc="00"
       apn="cmwap"
       user="*"
       server="*"
       password="*"
       proxy="10.0.0.172"
       port="80"
       mmsc="http://mmsc.monternet.com"
    <apn carrier="Android"
        mcc="310"
        mnc="995"
        apn="internet"
        user="*"
        server="*"
        password="*"
        mmsc="null"
</apns>
I know I have that however metro is not in that list nor are sprint, vzw etc. Like I said apns-conf.xml is not used in Lg's stock to provide metro's apn settings and thats why I am asking for them.
I could open telephony.db/Providers and there's not metropcs inside of it.
This is the file.
That's because metro, depending on the area uses different networks, such as sprint and Verizon in some cases. Another example is that both cricket/us cellular both use metros networks, and metro uses theirs.
Code:
<PreferenceScreen>
&#8722;
</PreferenceScreen>
Code:
<apns version="6">
</apns>
i flash phones to cricket for a living... like u said, telephony.db, apns-conf.xml are not utilized in oem setup for cdma lg androids. i have looked at lg ally, and lg vortex for example. manipulating those files have not gotten me anywhere. on a interesting note, lg optimus s from sprint uses those settings however..... lg vortex on stock does not contain hidden_settings.xml in the mms.apk that i could find. the mms settings / actual apn being used are in a different place that i have not found yet
