Help Apn settings?
Installed a new sms app next session. Since then I can't download mms. Get an error saying I need to set up apn settings don't know how to though..
Let us know which phone you have and the android version it's running and who your carrier is, and we can try and figure out the proper APN. I tried looking up that app but couldn't find it. Is it in the play store?
I found the following for Alcatel Phones on MetroPCS ....
Select Settings > Wireless & networks> Mobile networks > Access point names
Press the Menu -> New APN
Enter name: MetroPCS
APN: fast.metropcs.com
Proxy:
Port:
Username:
Password:
Server:
MMSC: http://metropcs.mmsmvno.com/mms/wapenc
MMS Proxy:
MMS Port:
MCC:
MNC:
Authentication type:
APN type: default,mms,supl
Keep default values for all blank fields shown above.
Hope this gets you connected. :)
Try a Google search for "metro pcs APN MMS" or similar
Did mms work fine before you installed this app? If so I'd guess it's the app that's at fault and not your APN
