charlieanne
Hi, firstly I apologise if this thread is in the wrong place/already answered but I can't find anything to help me!
So my problem is I cannot get a data connection at all. I have and never have had a 3g/H/H+ symbol. I have standard signal bars and can make and receive calls and sms and I can access wifi fine, but cannot access my data. Orange assure me everything is fine their end and have sent me APN settings multiple times but they do not seem to work.
I bought my phone on Orange via phones4u. As such the phone is factory unlocked and unbranded. My sister's sim works in it, but again no data despite adding new APNs.
I have checked my APN settings and I think my issue lies here. I added new APN's (several times) and they do not work. I was advised to reset APNs to default which has not fixed the problem.
The default APN to my knowledge is correct EXCEPT the MNC field, which is 33 and all other APNS I can find for EE/Orange have MNC 30. However I cannot edit the default APN or remove it. I cannot add a new APN if the MNC is anything other than 33.
I am running Android 4.1.2, which to my knowledge prevents me from downloading an app to edit the APN.
Do I need to do a factory reset or root my device? I am a noob and I am hesitant to do a root myself.
I can't seem to find anyone else with this issue and I am getting p'd off!
Also I'm on Network Mode GSM/WCDMA the only other options are GSM only or WCMDA only.
Thankyou in advance! I really appreciate any help or advice!
