Help App Brain Sync Problem
Barats
Ok all of a sudden AppBrain does not sync with the internet when you try and add apps to your list to be downloaded later and it does not show me updates at all anymore. They only show through the Market, not AppBrain, which is what I prefer. And I really like it when it syncs from the internet to the app on the phone when it comes to picking apps you want.
I tried logging in and out and it did nothing. I added 2 apps to my list and it is not showing at all on AppBrain. Any help??
Not sure if you're rooted or not (not even sure that an Evo CAN be rooted)
but if you are and you've been ROM jumping you may have more than one list in the upper left corner of the AppBrain website. If you do, make sure that you're adding apps to the correct list, otherwise they don't show on your phone to install.
