Romparoo
I wanted to know, especially those who came from the Dinc1 or similar HTC phone, what you thought about the scrolling speed/functionality on the Dinc2.
I noticed, when I played with the display model at Verizon, that it absolutely stinks! I'm not sure if there is a setting option to it or not. I found that I can not scroll quickly with just a fling of the finger, but instead I have to scroll with my finger multiple times to run through all the apps.
I did notice a side bar on the app drawer. I am not sure if that expands with more apps, which then might allow you to fling your finger quickly through the apps.
On my Dinc1 I have 200 apps in my app drawer. With one fast flick of my thumb I can go from the top of the apps to the end of the apps. However, with the Dinc2's I have played with I can not do this, but instead only 1 or 2 lines at a time.
The reason I bring this up is because I find this as a huge annoyance. If this is true and can't be fixed within settings then I will wait for the Dinc3 or some other HTC phone before I upgrade.
Thanks.
Thanks.
