Flaspeneer
Even with stock earbuds, the Epic's lowest volume setting is hot enough to cause hearing damage if used over long periods of time, particularly if the style of music being listened to isn't classical and has a continuous loud dynamic level.
With higher quality earbuds like the Etymotic HF2, UE Superfi 5vi and Shure E4c (all of which I've tried), the lowest setting becomes unbearably loud.
Since the music player and system adjust the same exact level, there's no way to affect the gain structure of the Epic, which means that better earphones become painful to listen to -- which is a shame, since the Epic sounds good out of the box and benefits from the upgrade.
Does anyone know of a different music player or app that allows you to adjust the volume to lower levels than the system volume currently provides?
