Newb question. Can you save a scene using launcher pro? Like many I've become addicted to switching my layouts but would like to go back to old ones somehow. If not is there an easy way to go back to your old settings?
In the menu you can save your layout. Widgets will not be saved unless they are ll widgets. In order to save multiple you will have to rename them I think....for some reason I remember them having a generic name and being overwritten with each new save but they may be date coded.
Hit the menu button from your homescreen, and take ADW settings. There should be an option near the bottom for backing it up. You only get one backup though, so any subsequent backups are saved over older ones
