Help app help
I need help really bad.
When i Download a app it puts the app icon on the screen and yes i am not running a custom Rom or any other version of android i am running stock android
but i am rooted :D so if i download a app say angry birds it puts the icon on my home screen this is not suppose to happen it really puts it on my screen not in the app drawer on the screen. So i think this a root issue should i unroot then root back again or do a factory reset :(:(:(:(:(:(
i am running go launcher ex and go locker (the best lock screens every) so when i downloaded a theme for go locker it puts a icon which is not suppose to happen it nevers make a icon for a theme. If you do not understand what i am talking about here is a shorter version.
apps that are not suppose to make icons make icons and put it on my home screen i think this is a root issue
did any of you guys using the Samsung admire and rooted happen to you i need to know
n0ob question right there
I'm pretty sure if you look in the phone settings, under aplications, there shgould be an option to place a newly installewd apps shortcut on the desktop. once i have3 my phone in front of me i'll double check tho...
so i did a factory reset for noting that is just crazy i am restoring it right now with titanium backup well the app data because i want the market to know i have the app so thanks
