Help App info move lo SD
jaybo1973
Android Expert
Hi guys
ICS is different when you move an app to SD. Before when you moved an app to SD, you could see the app get smaller. Now the app seems to get bigger. Not sure how this works now. Any ideas?
All the data seems to move to USB storage app. Not sure what this is. Even though apps have been moved to SD. Some are showing 0 on SD and the bulk of the app size on the USB storage app. Can anyone explain?
Thanks
Cheers guys
Can anyone help on this? It looks like I was drunk when I wrote the message.
To summarize, what is USB storage app? When I move an app to SD, it moves there rather than to SD. Is this part of the SD or something?
An example, sorry this is duplicated in some other posts:
App info
World of goo
Total. 34.48mb
App. 412kb
USB storage app 31.52mb
Data. 2.56mb
SD card. 0.00mb
It appears that there is nothing on SD even though the app has been moved. Most of the app has moved to USB storage app, whatever that is?
