Basically I downloaded the Angry Birds app on my Wildfire and when I try to run it, it goes onto a white screen and plays the music but no game! I have tried re-installing and everything
It doesn't work on the low resolution screen im afraid.
Load the game and wait 10 seconds then press the power key then again unlock the screen and it should work if it doesn't try again. locking the screen and unlocking.
make sure you don't exit the app.
yeh the processor isnt fast enough works well on overclocked but the game is a memory hogger anyway. Also the screen resolution on the wildfire is qvga and most games dont support it.
