Root App problems
DSG04lightning
Ive been trying to Install an app called RC Flight Log from T3CHdad. Ive looked everywhere for it and cant seem to find it. The developer says its compatible and i shouldn't have any issues. Everywhere meaning market, app brain, amazon app store even tried scanning a bar code on his website to download. But i found it no problems with my buddy's incredible.
So im thinking its a root issue kinda like the netflix thing before it was made compatible im on the 595 build rooted. Is OTA rooted yet? trying to decide if i want to SDF back to stock 340 and install the OTA? anyone have any work arounds?
No the OTA is not rooted yet. And you could be having the problem with the market not showing all the apps properly. All you need to do to fix that is use the market fix here,
http://jrummy16.com/jrummy/testing/fix.apk
Or if that doesn't work try this method,
http://androidforums.com/droid-x-all-things-root/339396-need-app-market-help.html#post2711246
And if those don't work remove the updates from the market in manage applications and you should be good to go.
Looks like the Jrummy16 fix worked im good to go thanks for the infomation
