Help application has stopped unexpetedly
sirius
Hello everyone. Over the past few days I am noticing several of my 3rd party applications such as Shazam will not load and I am getting this error:
The Application Shazam (process com.shazam.android) has stopped unexpectedly. Please try again.
then there is a force close button below that.
Any ideas other then a hard re-boot?
Thank you for your help
Do you use a task killer? I recommend a re-boot, then letting the phone sit for a couple of minutes use a task killer or settings to see what is running and using resources. Try opening one of your "problem" apps. If you get a force close message, close the app and then use task manager to kill all your background apps and try again with the "problem". You could have something hanging up in the background.
