Help Application/internet problems
melly1919
Hi
I have the HTC Desire
This morning whilst i was looking through my mobile, i went to the manage applications section which i have done various times before, however i managed to press the 'force stop' section on the anroid system tab and i also did the same on the accounts and sync tab, since i have done this i have been unable to get onto the internet when using the mobile networks, i can however use the internet if i am connected to my wifi, i have tried to sync etc but nothing changes, when i look at the manage applications section and go to the running application it now shows accounts and sync 0.00mb and anroid system 0.00mb.
I have also noticed that when i have switched from the wifi connection and try and connect to the mobile connection it takes a lot longer to connect, it shows its connect however it still does not let me on.....you help would be greatly appreciated :):):):)
