UniqueProblem
I was wondering if anyone can help me before I uninstall the program this is my last option as I have searched all over the net for the answer but found no solution so this might be my last stop.
I have installed Brothers in Arms 2 HD after giving it a trail run I exited the game. However I have read that exiting does not necessarily mean the application is closed. I decided to then check applications which are open and eating my battery life.
Settings>About Phone>Battery Usage, here it shows me Brothers in Arms 2 HD 6%. When I click on it to Force Close, the option is in-active. So I decided to go through the Task Manager option and check out the Active applications but nothing is showing up here. So my final option using the Phone features was to go back into Settings>Applications>Manage Applications then click on the running tab but nothing was showing here. However every time I go to Battery Usage the game shows up still using 6%. My other option was to go and download Advance Task Killer but this did not achieve anything.
I try to reload the game and exit, no solution still showing.
Then I thought it may be a delay and it will exit soon but I write this post after 2 hours still showing up under battery usage not going away.
The only option I have is to uninstall the game but I don't want to keep uninstalling apps if this happens again if there is a solution.
So in short I see the application under Battery Usage but nowhere else to close it.
