Help "APPLICATION NOT FOUND!!" HELP!!
On my Xperia Z2 tablet I have a bunch of application not found icons. I don't care about the data I just want the icons gone. Can anyone help me? 2015-10-09_22.23.03.jpg
I'm guessing you could either long-press the icon and select Delete/Remove if a mini-popup gives you that choice OR you should be able to long-press it and drag it to a trashcan icon or an "X" that will appear when you've done the long-press.
It just does this:
