Help Application Not Installed
ynwa
Changing from Desire to the Desire HD. I am trying to install mybackup to transfer all my applications etc over. However when i try to install it i get the message "Application not installed". Tried to install another app and i am getting the same message. App updates are not installing either.
Yeah Dan done all that, still nothing will install or update. Lots of space on phone and sd card. Frustrating as im eager to switch over to the DHD. Cant do a reset either as i would need to backup my apps etc before doing that.
Did you do any tweaks on how applications are installed? Such as changing it so all apps install on sd or anything?
How much internal memory is free?
Yeah changed it so all apps install on SD Card. Worked fine for a number of weeks now not installing at all. Have 20mb+ free phone the phone. 4gb free on the card.
I've seen others who have done that have this problem. Solved bymoving back / reversing.
May need to lose some apps though.
Got it sorted Dan. No idea what caused it but i think it may have been down to debranding the phone all those months ago? Reason i say that is it is now installing and updating after i changed my memory card over to my Gold Card.
Debranding these phones does seem to cause a fair amount of trouble if you dont always use the Gold Card.
Hey! Delete file .android_secure/smdl2tmpl.asec from SD card.
If the folder .android_secure is empty on file manager, delete it from PC
