Help Application on SD
D
Deleted User
Guest
Hi all.
I've used "O1" for almost 2 months now.
One thing I've learn, that not all application can be moved to SD card.
Either by using stock application manager or App2SD application (from market).
My phone already rooted (using z4root).
I too know there are some steps to do, involving partitioning SD card in order to enhanced this "app2sd" things.
The condition is :
1. I've used Transcend MicroSD 16 GB class 6, formatted using FAT32
2. I've moved some applications (that can be moved using standard way
on froyo) to SDCard. And no problem whatsoever.
3. I think I used stock ROM. But, using "System Panel app", the device
info is as follow :
Build ID : FRF91
Device : thunderg
Fingerprint : LGE/thunderg/thunderg/thunderg:2.2/FRF91/
eng.vijaykumar.n.20101019.134848:user/release-keys
Tags : release-keys
Type : vijaykumar.n
Who is "vijaykumar" ?
But, as I told earlier, not all applications can be moved.
Although, after I've installed Titanium Backup, I can move some
applications (like Yahoo Messenger) to SD Card. And the application
still run fine.
What I wanna know is,
1. If for some reasons, I wanna partitions my SD card into 2 partitions :
perhaps 90% FAT32 and 10% EXT2 (for applications).
Is this still possible without reinstalling all apps I've moved to
SD (prior reformatting) ?
2. And if it possible, what are the steps ? I can't find it anywhere.
Perhaps I underlook ? If already there, can you post the link ?
3. If not possible, perhaps I have to reinstall or something, any lead ?
I know for 100% that I have to backup everything from that SD prior
reformatting. :)
That's it for now.
Thanks for the reply (if any).
Thanks
