Help Application to restart/ shut-down phone
Hi Friends,
I do need to restart phone sometimes to make sure my internet works.
Is there any app available which can help me doing that and maybe to switch-off phone as well? I do use hardware key currently, but want to minimize the usage for better longevity.
I'll appreciate any help. Thanks :)
I've found, since after the OTA update only, that if I have WiFi enabled, I disable it, then try to turn data on, .......no go. It just doesn't happen.
If I reboot the phone, it reboots with data enabled.
Only since the update....
