Help Applications don't connect through mobile network.
HI I'm trying to connect to market via mobile data network but the application doesn't establish connections.
I have unnactivated wifi just mobile network is on but that problem is present with almost all applications like twitter, gtalk, gmail.
I don't know if a configuration to force the use of mobile network exist.
I'll be gratefull with some help.
It is just the market?? The android market has changed to google play. it will be a new app in your app tray called play store or play shop. When this changed on my phone and on others i have seen you will still have a green market icon that won't do anything. look for an icon that looks just like the green market icon but it is white. I don't know if this is helpful at all but will rule it out :)
