Help Applications Limit
ravi224
Hi...
I am using HTC sensation 4g and i want an advice regarding the applications limit.
Usually i install around 10-15 applications daily and also uninstall if not satisfactory. So, i want to know if it is safe to install that much applications or will it affect my phone.
Kindly help me on this.
Thanks..
I do the samething all the time and last time I checked I had close to 200 apps on my phone and my phone runs fine
Depends more on what the apps are than the quantity, if you have applications that are running background services then it will start to slow the phone down.
