Applications wont rearrange
umadbro
Member
If I uninstall an app its space will appear blank and the other apps wont move into its place. How can I fix this?
I noticed this also just yesterday, anyone else?
edit: ok I know its not an auto adjustment but... if you go to your apps, then press your edit button, you can drag an app to the empty space, if that what you want, otherwise I have no answer to why the empty app space is not filled automatically.
I hated this issue as well, found an app called appzorter lite, this sorts your apps alphabetically and also fills gaps. All is well with the world once more.
Does go launcher replace the touchwiz front end? ie. once intalled can you swap between the 2 when you feel like it or do you have to uninstall go launcher?
If you uninstall go launcher, will all your original touchwiz screen layouts still be in tact?
No, you can swap between the two. I set my home button to switch between the two:-)
And yes, touch wiz will be there when you want to go back to it.
