Root Applied leaked RUU and lost root
dneiding
I updated my DINC this morning using the leaked RUU and it worked perfectly, booted up and went to install Titanium Backup and noticed that I was no longer rooted. Do I just re-do unrevoked or some other root method to get root back?
if you have s-off, just grab the PB..IMG file from unrevoked to add the clockworkmod recovery back on and u should be ok.
If you used Unrevoked Forever to get S-Off, you'll be ok. If you didnt, then you have to wait for the devs to figure out a way to root the new 2.2.
I'm assuming with S-Off that just running unrevoked3 would work?
Not quite. But they have instructions on their faq. Basically you just need to manually install the custom recovery again.
