Help Apps/Icons on home screens
klz
I am having an issue with my Warp where when I move an icon on my home screen it will not set on the screen. This happens most of the time and I usually find the icon in a random folder on another home screen. To be a little clearer if I install a new app and I want it on one of my 5 home screens I'll drag it and when I try to set it on one of the screens it disappears. Anywhere from 1-20 minutes latter I'll find it in a random folder. Does anyone have a workaround/solution for this problem? Anyone else even experience this?
Thanks
are you rooted?
you can try going to settings/applications/all/launcher and hitting clear data. after that reboot and try adding shortcuts again..
another thing to try would be a long press on the screen you want a shortcut on and adding a shortcut that way.
lastly, you could go the drastic route and root your phone and change the launcher to a different one, I prefer the ICS Launcher or the GO Launcher, both are free on the market... if you want to do that, check out the all things root forum and look for the one click root, then you can simply add the application from the market... the launcher is what controls the functionality of the home screens and bottom row of icons etc.
  • Like
Reactions: klz
