Help Apps keep crashing and force closing? HELP?
Sammh421
Hi, I have a Samsung galaxy s2 and at first it was just the twitter app that crashed, and now others are starting to crash and then force close but not as much as the twitter app which basically won't let you go on it!
Has anyone any ideas whats causing the problem? So far I've reinstalled the apps and that failed as the problem still persisted so I then factory reset the phone and I'm having the same problem...
Any help or tips? I've cleared the apps cache etc...
Any help would be much appreciated! Thanks! :argh:
