Help apps launch slower when not on wifi?
dennygreen
has anyone else noticed that when you're on wifi, your apps launch as soon as you touch them, but there's usually a slight lag when you're using Mobile data?
I dunno if I never noticed this until now or if its a new problem. it's really annoying now that I see it.
Hmm thats odd i just tested this and im not seeing any difference at all i tried on TW and i also tried on nova launcher since nova is my normal launcher.
ok thanks. yeah, I used nova for quite a while and then switched back to tw a few days ago.
doesn't make sense to me that switching from wifi to lte would make a difference like that.
well, I switched back to nova and it did the same thing.
so I did a factory reset and that fixed it. thank god. that was annoying.
Glad you fixed it and yea i prefer nova over TW just cause i cant stand TW and all the little minor bugs here and there i found in TW nova took care of
that didn't seem to do anything. weird.
I guess I'll do another factory reset at some point, that worked pretty well last time. it's gonna get old resetting every couple of months though.
