Hello everyone
I'm new to the Android platform and have run into a problem with htc wildfire.
It's running Android 2.2.1 and won't show me which apps are using the battery in the battery usage menu. It did before I upgraded. Has anyone else experienced a similar issue and have you found a solution for it.
I'd appreciate any light you can shed on it. Thanks
