Help Apps Organizer v Folder Organizer
bunnisher
Member
While trying to do a massive clearout to regain space, I see that my Folder Organizer Lite is massive and keeps being updated and getting bigger.
I only use it to change icons and have only created two folders.
Is Apps Organizer better for such limited use? It appears a lot smaller too. Is it really smaller?
Before I delete stuff I want to keep just so I can download App Organizer to try it out, will this app do what I want and be a smaller app? What are the main advantages to keep Folder Organizer?
Thanks in advance.
Amazed no one has replied in all this time, I wanted to know, too...
In the end I DL'd it and played with it. As far as I can tell, you can't use it for changing icons, which is one of the main features I thought it had. Maybe it can and I just can't work out how, though...
MIght be a good idea to post links to both apps. Please check on Market what reviews the apps have.
