Help Apps settings on phone won't save.
Hello, I'm a first time poster. I just got my first android a few weeks ago and just started reading these forums (thumbs up btw). Anyways my samsung infuse was fine but I reformat it after getting my 32gb micro sd card and ever since the apps settings on my phone won't save.
For example everytime I start the app it is as if I just downloaded that app. I do not have my phone rooted or anything but I do have the *load app from unknown sources* checked. It's been pretty frustrating since every time I want to use an app I have to configure the settings again.
Just a heads up since is this my first smart phone ever I have absolutely no clue how to fix it. If anyone have any suggestion of how to fix my problem please let me know. I thank you in advance.
i had the same problem with some apps..i figured out that some apps especially that have widgets needs to be installed on the phone mem to work properly..so goto that app thats giving you problems under setting and application and move the app to phone mem instead of SD card.
Ahh okay thank you so much for the reply I will give it a try. If it doesn't work I'm thinking of restoring it to factory default setting and see if that works. I do have one follow up questions though if I reset it to factory default setting will my SMS get erased? Thanks again
Edit: Is moving the apps to phone my only option or is there a way around that so I can keep it in the SD card?
yes if you restore your phone u will lose all your sms..
well for me i dont install every app on phone mem..i only install those that needs to be on phone mem..but most reg apps its on sd card
