Apps that drain your battery!
andrew8806
All of you Androidites!!!! Please list all of the Apps you have known or seen drain your battery. So we can stay away from them or use an alternative app!
I don't know if you wanted specific games or not, but papi jump, very fun btw, loves to drain the eris.
Meebo IM is a drainer monster. Takes in more battery life then the actual Android System itself.
Not that I'm an expert here by any means, but maybe it's an older version? Seems a little less sharp than the newer one.
HTH,
PC49
That's funny. I was using Meebo IM just a few minutes ago and in one minute my battery prediction went from 50 minutes to twenty minutes.
Try using E-Buddy IM... It seems to do better on the battery and I actually prefer over Meebo IM
where do you get those icons?
Its called "Tenuis Icon Pack", you can get it free in the Android Market :)
I actually like Meebo better than Ebuddy, so I just use Meebo.com on the web browser.
How come on some Android Phones I see an application called "IM" where you can use AIM and MSN and stuff like that but I dont see it on the Eris.
The IM app is even in my Manage Applications list, but I don't know of any way to run it since it won't show in the home app list.
Streaming Pandora and Slacker would drain my battery, but I think I found a fix. I just received this 1700mah battery from Ebay. It wook almost 3 weeks to receive it. I am trying to drain it now to begin a 3 day process and see how much extra life it offers to me. The battery is the right length and thickness. However it is about 1 mm shorter on the width side. So it stays in place but does not cover the same amount of area as the original HTC battery, but it works and it was only about $8.
1700mah Spare Battery for HTC G3 Hero Tmobile G2 Touch - eBay (item 230411706061 end time Jan-11-10 18:07:10 PST)
I am actually going to order another one that is 2000mah to see how that works.
2000mah Spare Battery fo HTC Verizon Touch Pro 2 XV6875 - eBay (item 390136111780 end time Jan-26-10 06:04:22 PST)
