Help Apps to Sd card Help
It will be, a little later :). In theory, after you root your phone (which is not yet recommended because it's a difficult process and the rooting is still unstable), there are some steps which allow you to save the apps to the SD card.
But for now, NO. There is no other way I know about.
tis a lil bit complex and they've really fixed it
tis quite stable and fast
I hardly get any errors (hope so it stays that way)
and app2sd is also working after the initial confusions I'd
I've just seen you over at xda's and wanted to ask if you did it :)
So hoping in a few days we'll see a tutorial from you. I'm thanking in advance ;)
it took me like 5hours to sort out the confusions...lol
anyways I guess the instructions der are quite clear and a detailed tut is not possible as I'm out of bandwidth lol
