steslatt
Android Expert
A couple of days ago i was low on memory so i decided to take the plunge and root my device with a custom rom and take advantage of apps2sd+ This all worked out fine and gave me the the space i needed. The phone was showing around 140mb of free space with most of my apps installed and from titanium backup i could see that the partition was being used. However after a couple of days i have noticed that my internal memory is back down to 16mb. I have cleared the caches and dalvik cache. The only thing i have done since the change in memory is move my sim contacts to the phone, moved the apps that can be moved to my sd card and installed a few new apps.
Is there an app i can use to see what is taking up all the memory? if not how can i rectify this problem?
