deanshep85
Android Expert
now yes Im aware that if we create a 1GB ext partition on the memory card for Apps2SD to work is it possible to actually use the non ext partion for apps occasionally?
What im asking is some games when they install and download their extras can be VERY large say for example asphalt 5 etc can be like 90+ MBs....can I install it and push it to SD and it will work correctly or will it install it partly to the internal or ext partition part?
