Root Apps2SD help using GOT Open Recovery 1.04
Profcool
Hi all, I am having problems getting Apps2SD to work on my Milestone and I am looking for some assistance. I'm sure I'm missing something obvious but I think I have followed all the steps required to get it running.
I have GOT Open Recovery installed and have factory reset my phone. From there I have used the tool within Open Recovery to partion the SD Card (16gb) and then installed Apps2SD.
When I install any apps they are still installing to the phones memory rather than the SD card (I can see the internal memory being reduced by the same amount as the apps size). Can anyone help and advise me what I need to do to get this up and running?
Thanks in advance
