how much internal memory it shows?Ok iv read thro dans thread again and noticed it says that if a2sd has more free space than used then its not working and when using quick system info im only using 21% is there anyway to rectify the problem. Cheers in advance
Maybe one of the seven dwarfs read it to her...You misread.
I said if the free space shows less than the total space then it is working.
