Help! I downloaded the aquarium live app for my wallpaper but when I go to change it the option is not there. How do I get it active on the my touch slide
MTS does not support live wallpapers. The processor/gpu is not really fast enough. Techinically you can root and run the live wallpaper, but thats not worth it, you will prolly end up with 2 hr battery life. Live wallpapers use lots of battery.
So ya, you can't run live wallpapers on this phone, sorry.
that's a load of crap... I have been running live wallpapers since I rooted my phone over a month ago and every one I have installed has ran very smooth (including the scrolling Mario one) and haven't killed my battery that quick. the only way it would kill your battery anywhere near that quick would be if you set the screen timeout to "never".
the only time they "use up power" is when the phone is awake and on just the home screen.
to the original poster if you want to learn more about rooting, installing custom ROM's and such xda-developers is your best bet.
