how would I get ENG S-off?
as I already asked him this...
Well, theres a tool that gets you your engineering hboot...but the guy took it off....
I would offer to send you the application that I had installed before , but DURX will indefinately say that this is a grey area etcas I already asked him this...
Found a link with it on (per above)... so there's no grey area
I wasn't being funny... I couldn't give you it, as I did not have a copy!
just becasue youre using a tool,doesnt neccessarily make it 100% safe.
I've always been told that you must have ENG S-Off to flash radios... guess you learn something every day![]()
Decided to try Android Revolution. My current radio (12.65.60.29U_26.14.04.28_M) differs from the recommended radio (12.65.60.29_26.14.04.28_M) by just 1 letter!
Are these basically the same. Is it worth the bother to flash the radio?
When you rooted, did you use the AAHK? If so, it doesn't (as far as I remember) give you ENG S-Off.
6 - Install your own Radio or "PD98IMG" style ROM
Obtain a COMPATIBLE Inspire/Desire HD Radio in RUU format. Name the zipfile rom.zip and place it in the PD98IMG directory.
CAUTION: Flashing a radio incorrectly or a wrong radio can result in perma-bricking your phone.
7 - Remove PD98IMG.zip from SDCard (after hbootPD98IMG Flash)
Run this after any hbootPD98IMG Flash
