Root Aria: All Things Root Guide
Status
Not open for further replies.
El Presidente
Beware The Milky Pirate!
*** Important Note ***
Since this is a new root guide for your all-things-root sub-forum, we need your help to populate it and keep it organized with the best and most relevant information. Please contact (by PM) your favorite Guide, or drop us a note in the private chat section if you have any good information to contribute, update, or correct in the root guide. Alternatively, hit the
button and ask a Mod to bring it to our attention.
Thanks for your help!
Click the "Show" button below for a root warning / disclaimer:
Quick note / disclaimer: as always, you are ultimately responsible for any root-related activities on your phone.
You should understand not only the benefits of rooting, but also any possible consequences (voided warranty, boot-loops, bricking, etc.) that might occur as a result of your root-related actions.
AndroidForums.com / Phandroid.com, its owner, and staff are not liable for any root actions you might undertake as a result of information used from this site.
Reading, researching, understanding, and carefully following the published steps and instructions can go a long way towards helping to make your rooting efforts a successful one.
General Information
Guides
  • Rooting (and loads of other useful info)
  • un-rooting guide
All drivers from above must be installed
1: Official 2.2 ATT Update(NOW Rootable!!Guide HERE ) or ATT 2.1 Update Download MIRROR(Rootable)
2: Make sure USB Debugging is checked in Applications/Development(if the process hangs for a long period, try again with Debugging un-checked)
3: Run Aria Shipping ROM.exe as Administrator
---Follow on screen instructions, may take up to ten minutes
  • removing apps guide / safe apps to remove
1: Once your phone has been rooted with Clockwork, boot into Recovery(hold volume down/press power)
2: Open CMD prompt, get to the "android\tools" directory
3: In recovery window highlight "Mount System"
4: Plug in data cable, in CMD type adb remount
5: Now enter adb shell
*you can view the list of apps stored in the phone by entering ls
6: To remove an app enter the following: rm whateverapp.apk, then enter rm whateverapp.odex
(example: rm HtcFacebook.apk ENTER then rm HtcFacebook.odex ENTER)
7: Type ls again to confirn they have been removed, reboot phone.
*NOTE: you may get 0.0dip listed in Widgets menu. simply go into Manage Apps and locate HTC Sense. Open it and "clear data". your display settings will be reset to factory, but it gets rid of the false data.
  • various how-to guides, etc.
ROMs
Themes
Overclocking / Underclocking / Undervolting
  • overclocking / underclocking
  • undervolting
  • related apps
Kernels
  • None as of yet
Radios / Basebands
  • None as of yet
Tools & Utilities
Downloads
Cheers!
Status
